Well, I guess I was wrong about that...BTW, I always thought the "process" was a DSP algorithm. If you're gonna build this you will need the source code
BBE - Sonic Stomp ( Sonic Maximizer )
- DougH
- bajaman
- Has thanked: 568 times
- Been thanked: 2014 times
the search engine is your friend - use it
- CHEEZOR
I used the search and I couldn't find any (there were some, but the links are down). I own one of these and I will gladly take a picture of it for you, but I wont be home until probably tomorrow or the next day. So if you still haven't found one by then post a response in this thread and remind me to take a pic for you.
- CHEEZOR
https://img52.imageshack.us/img52/16/1004772g.jpg
There. I hope that helps. Let me know if you need anymore at a different angle or something or if you just want to verify a connection.
I am a little red faced here.....
All I did was to follow the gut shot to replace the switch to the tee!!
All wires are in place and good solder joints... and pow....another problem..
when I click it on it acts as a boost pedal, the low and process works but its like 25 db louder when on??? what gives?
I should quit tinkering and take it in I guess...
Any thoughts
Many Thanks
Tinkering Bob
Any thoughts
Many Thanks
Tinkering Bob
